General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
No high beams - no bright lights
Old Apr 29, 2009 | 07:29 PM
vrgl1976's Avatar
has anyone come across this? my low beams are fine but hit the brights and nada no light, the dash indicator comes on but the lights just go off. put in new bulbs. is it the switch or the relay?
Last edited by waskillywabbit; May 1, 2009 at 04:51 PM. Reason: Title clarity per posted sticky
Old Apr 29, 2009 | 07:37 PM
MILLER 88DLX's Avatar
I had the same problem last year. It turned out to be the combination switch that controls the lights, wipers and turn signals. I got mine on Ebay and it was easy to install.
Old Apr 29, 2009 | 08:32 PM
4Crawler's Avatar
Yep, common problem. Often just dirty or pitted contacts in the dimmer switch:
- http://www.4crawler.com/4x4/CheapTri...eadlight_Combo
Old Apr 29, 2009 | 08:35 PM
toylocost's Avatar
From: Yotatech, because Pirate is too expensive. NorCal.
when you pull back and use the flasher do they turn on?
EDIT: 4crawler beat me to it. I was gonna put that link up. I just fixed mine today using that page. A little different on my first gen but you wont have that problem.
Old May 1, 2009 | 03:02 PM
vrgl1976's Avatar
no brights either way but ill try and give it a good cleanin see how that goes
Old May 19, 2009 | 07:38 PM
elblako91's Avatar
I remember there being fuses for your high beams in the fuse box in your engine bay. Might want to check them.
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
HookahRoo
Jul 20, 2015 07:06 PM
redghost.308
California SoCal
Jul 16, 2015 07:46 AM
Jake28296
Jul 12, 2015 10:15 PM
