93 toyota wont start
Old Apr 19, 2009 | 07:22 AM
made2win1's Avatar
has spark, fuel, timing right on im baffled
Old Apr 19, 2009 | 07:50 AM
nv4runner's Avatar
Since it sounds like you've checked the Battery, Ignition, and Fuel, you should check for air now. Remove the intake tube at the throttle body to see if it starts. If it doesn't then do a compression check. If compression is low and the intake tube is still off then loosen the exhaust and see if that makes a difference.
Old Apr 19, 2009 | 09:13 AM
abecedarian's Avatar
how can you check the timing if it won't start?
what work's been done to the engine recently?
Old Apr 19, 2009 | 09:34 AM
91Toyota's Avatar
Tried turning it over?
6th Gear
19
Dec 10, 2019 07:31 AM
Crazychris1871
Jun 27, 2016 10:38 AM
vasinvictor
Jan 20, 2016 12:39 PM
Dennis140
Jun 17, 2015 10:37 AM
