Anyone have experiance with this 22RE head off Ebay?
Getting ready to do a complete engine rebuild and want some more power looking at this head price is good but don't know any thing about them hoping some of you here might.
http://cgi.ebay.com/ebaymotors/NEW-2...Q5fAccessories
Last edited by waskillywabbit; Apr 13, 2009 at 06:50 AM. Reason: Title clarity per posted sticky
I bought a head from J & C Enterprises a few years ago and I haven't had any trouble out of it at all. Mine was remanufactured and they installed the engnbldr oversized valves and a Crane Stage 2 cam. I don't know why they changed their name from J&C to what it is now but it was J&C Enterprises when I bought from them.
I assume mine was a remanned OEM head so it's not the same as that one, but I had experience with the company so I thought I'd chime in.
Hi,
I bought a new head of ebay- used are touchy for electrolysis. Not this guy- he doesn't ship to Canada. Most are made offshore (read China) the casting and machine work seem better than oe, but 19 years does make a difference in manufacturing. I cannot vouch for the alloy. I put Engblders OS ss valves in had them back cut, and a set of his springs, the smallest Comp bumpstick they make for the 22r(e), lightly ported the heads, intake, and TB. Just sitting there looking pretty until I get off my ass and do the timing chain. Careful with the gaskets use OEM that incudes valve seals.
Just don't buy one from cylinder heads international. They don't do quality testing and sent me a cylinder head with faulty valve seals. My 4runner smoked bad on startup. Had my old cylinder head tested and repaired as necessary and it worked perfectly, no smoke, ran great.
Hi,
Will keep updated after the TOUR to see if it was worth it or not
I know this thread is old; but the head J&C just shipped me was such a POS
I am taking time out of my day to bash them.
I got their "High performance" 22RE Rebuilt Head off E-bay with the Engnbldr O/S Valves in it. It looked nice to the naked eye... well mostly...really it was just clean.
I took it to my local trusted machine shop and the dude who had just finished my shortblock, which i was there to pick up; inspected it with me (for FREE)
He took out 1 intake & 1 exhaust valve and we inspected...The "Free Spring Height" should be a min 1.910" i believe. The 2 we had out measured up to 1.853" & 1.842". Below spec and in need of replacement. Then to the spring pressure, a HIGHLY IMPORTANT number! Spec is a min of 66Lbs or replace, J&C's came to 50 & 45 respectivley. REDICLOUS!
When I aksed J & C about the valve springs and told them what i had found they told me this. "Those springs are not new, they are used and out of another motor which is not a toyota that has higher spring pressure." I said BUT THEY ARE WEAKER THAN NEW STOCK SPRINGS!
J & C said "If you dont like the head sent it back"
Weak springs lead to "Valve Float" which is where the engine dosent run properly because of valves not opening or closing in a timley manner from weak valve springs.
Then we checked the top of the head where the valve cover gasket goes. Not straight at all, 1 whole side was crapily welded on and ground (not even straight at all). The valve cover gasket would have leaked from day 1.
Now on the the milling... Before i purchased this head I called them and spoke to the head dude. When I asked him how much the head was milled he replied "We mill .020 (20 Thousandths) off all of them". That is a lot, near the limit. Being on a budget i still went with it.
When my machinist measured it they had milled it .040!!! Twice what they said. My machinist told my the max was .020 to .025 and at .040 the head was garbage. He said he would never mill a head that much as it is past spec.
All in All it was a total POS in every way! Now they are delaying the hell out of my build and screwing around with the return/refund process!
Bottom line is this NEVER BUY A HEAD FROM THESE IDIOTS, THEY SUCK!!!
Well I'm hoping OlHarley didn't get that one...That really sucks that you had such a time with them. Now I have not priced heads at a bone yard lately but why not get one from there and have it done to your liking? I think that's what I would have done. At least have yours redone. Just my thoughts.
For $497 you can get the brand new Engnbldr Street RV Top-line head with the O/S valves & RV springs already in it & set up by a pro with these motors.
And no driving involved, shipped right to my door. Just sucks that J & C is so terrible. The old saying holds true "You get what you pay for."
Well guys as an update and a further reinforcement to NEVER BUY FROM THESE FOOLS... I would like you all to see how to use this as an example of; If it seems too good to be true, it usually is...... In this case it was.
After them royally f ing me on the POS they sent me; and me returning it to them. Which cost me $35 to ship + lots of aggravation (and I mean LOTS!)
They STOLE MY CORE! That's right folks not only are they totally incompetent when it comes to machining a head; they are THIEVS! They refused to send me my core back without paying $50 for S&H. I was yelling at the owner for long periods of time over several calls and this was the best they would do.
After contemplating things like calling their local police, filing a complaint with pay pal, ect.. The owner threatened to "Charge you the 35% restocking fee which the add states we can do." Much worse deal if they had done that. So I had no choice but to back off.
In the end they refunded me my $269 which was the original purchase price W/shipping.
And so now here I sit, built short block sitting in my garage still bagged from the machine shop. Empty engine bay, and out $35 bucks, a complete cylinder head, and about 2 months of aggravation.
I do have another 22re head in what seems to be sound shape, HOWEVER the cost of the valves + springs + S&H + machine work + gas adds up to about $430 - $500. Depending on what all work the head needs, even then you still have a rebuilt head. For $500 you can get the Engnbldr street RV head with the O/S valves in it. Sigh..... so now I’m about 230 short too...
Moral to the story: SCREW J&C ENTERPRISES!
They STOLE MY CORE! That's right folds not only are they totally incompetent when it comes to machining a head; they are THIEVS! They refused to send me my core back without paying $50 for S&H. I was yelling at the owner for long periods of time over several calls and this was the best they would do.
J&C did me pretty right. My head is still running strong.
No matter how tight a companies Q&A is there's always going to be a few that slip through the cracks. It's just a shame you got screwed as bad as you did there.
Harleyman yes you def. are lucky you didnt get this head! I think since you are within driving distance the return may have gone a bit better for you. You could have driven there and swapped them their POS for your core. The main problem with me was being in AZ i had to pay to ship them their POS and if i wanted my core back I would have had to pay for that too, which i didnt want to do.
Your offer gets more tempting by the day....
thanks again. I'll PM you if i decide to go that route. Ovrrdrive your good experence with them was one of the things that helped me decide to go with that head in the first place. Thanks for the input, it may have been a case of this one slipping through the cracks. However there were many things wrong with the one I recieved. Glad yours was OK. May just have been a bad core they rebuilt, and worn out used springs from a Non-Yota motor they used but I would hope they wouldnt be using bad core or springs! I mean all they do is heads!!! You would think they would at least bother to check this stuff...
Sweet @$$ Yota BTW
I also got mine a few years ago and anything could have happened since then. I'll also say that in the box it looked like a shiny new head but after handling it I noticed the nice new color was rubbing off on my hands. They had painted silver over the head to make it look new. They even pained the top of it so the paint would mix with the oil. Other than that though it has seemed like a good head.
Like I said though it has been a few years since then. I bought that head right after I became a member here so it has been since 2006. If they're sending junk like you got out now it may be best to avoid them.
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
