SR5 gauge swap question.
Old Apr 8, 2009 | 04:41 PM
small town BIG TOYS's Avatar
I did the sr5 gauge swap back in Jan. And there is one thing I can't to get to seem to work. And that is the low gas light. I check the bulb and that was good. If you did the swap (years 89-95) Did the low gas light work?
I am looking for input from people that have done the swap.
Thanks
Edit: A few days ago I almost ran the truck out of gas trying to see if it works.And this is on my 90.
Old Apr 8, 2009 | 05:13 PM
Junkers88's Avatar
I did this swap on my 89 (22re) and at the first fill up I put almost 14 gallons in there and the owners manual says it's a 14 gallon tank. The light didn't come on for me either and I know the bulb is good.
Old Apr 8, 2009 | 05:27 PM
Toyota Pete's Avatar
You have to have the sending unit in the tank that is equiped for the extra sender for the low gas light. If your fuel sender only has two wires coming from it it won't work. You'll have to go get a sender with three wires. I don't know if the truck is prewired for that option.
Old Apr 8, 2009 | 05:33 PM
Thanks for the info.
Now do you know if a sender from 3.0 91 4runner will work?
Edit: Do you know if the sender will be pretty munch plug and play?
Also my truck is a 22re and it was pre wired for tach.Thanks
Old Apr 8, 2009 | 06:08 PM
iamsuperbleeder's Avatar
hmmm, I'm going to have to investigate this some
I'm glad you brought this up!
Old Apr 8, 2009 | 06:27 PM
If you find anything out please yet us know.
Old Apr 8, 2009 | 06:37 PM
Flash319's Avatar
I didn't know any of the Pre 95 trucks had gas lights...............Non of mine have 88, 89, 92,95. All SR5 except the 88.
Old Apr 8, 2009 | 06:49 PM
I don't think the pre 89 toyota truck/90 4runner had the gas light.
But all the trucks I seen with the SR5 cluster (89-95) had the gas light.
Maybe it's different in Canada?
Edit: I did see one 86 toyota 4x4 pickup (non SR5 cluster) at wrecking yard with a gas light. But that is the only I seen ever.
Old Apr 8, 2009 | 07:23 PM
Windsor's Avatar
My '87 4Runner has a low-fuel light, works with both the "Deluxe" and SR5 instrument cluster.
Old Apr 8, 2009 | 07:31 PM
Silas's Avatar
My 1986 4Runner has a "GAS" or FUEL light that comes on when its almost empty...
My buddies pickup/other runners all have had them too as an orange square on the gas gauge in their 89-95 style.
Old Apr 8, 2009 | 07:55 PM
Ok I was wrong. But do also remember I never had a 2nd gen truck also.
I just had 2 83's and my 90 and that's it.
Old Apr 9, 2009 | 05:56 AM
cadman's Avatar
When I did the SR5 gauge cluster swap into my '89 DLX truck I had to replace the stock fuel sender with one that also has the fuel level sensor. The newer sender has the same pigtail, only four wires instead of two. Additionally, I also had to add a wire from the connector to the reserve light on the gauge cluster. If you have a transmission jack, it only takes about 10-15 minutes to drop the fuel tank to swap the fuel sender.
Old Apr 9, 2009 | 06:12 AM
rdlsz24's Avatar
My '88 has the low gas light and I'm glad it does since my gas gauge doesn't work lol.
Rob
Old Apr 9, 2009 | 10:28 PM
Rob
Yea I know what you mean. Same story with my 67 mercedes .
Old Sep 3, 2010 | 04:34 PM
red daw's Avatar
cadman I know its been awhile since this was posted but i'm in the process of swaping my dlx sender for a sr5 one. since my truck has two of the wires and I will be adding the one wire to the cluster what do I do with the 4th wire from looking at the schematic I only see 3 wires. Thanks for the help.
Old Sep 5, 2010 | 08:37 AM
red daw's Avatar
I have been doing a little digging and here is what I found. According to the 90-95 4 runner manuel the connector has 3 wires one for the guage one for the light and one to ground. I went out to pick and pull yesterday and verified that the 4 runner only has 3 wires. The one I got from the stealership was as cadman said 4 wires. So sense I know that 2 of the wires are for the guage I'm just not sure where the other two go I assume one goes all the way to the cluster but i'm not sure which one of the two and also where does the other wire go. I tried tis but I could not find a electrical wiring diagram for 90 pickups. any one else run into this? Or if someone would be so kind to scan that page out of their electrical wiring diagram. thanks
Old Sep 26, 2010 | 03:35 PM
red daw's Avatar
just in case anyone else runs into this cause TIS doesn't have the EWD for 90 trucks and the 4runner is slightly different. All 4 wires are run to the tank from the body eventhough only 2 are used on the dlx model. They run to a plug under the passenger seat. From there the one yellow-blue needs to be run up to connector D-3 on the cluster and voila low gas light.
Flying91
45
Apr 11, 2024 04:39 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
gary4runner
Sep 24, 2015 12:53 AM
88yodabasket
Jul 13, 2015 01:32 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
