Power steering belt twisting at the bottom when engine is running
It may be the pulleys aren't lined up properly, or there isn't enough tension on the belt ... or maybe too much causing the pulleys to flex.
If you remove the belt, is there any play in the ps pump pulley, meaning if you grab the top of the pulley and push / pull it towards the front of the truck, is there any movement?
voiddweller
19
May 2, 2016 09:10 PM
yourrealdad
7
Jul 21, 2015 08:53 AM
