Sponsored by: CARiD
Manual Transmission 3 inch Body lift
Old Mar 28, 2009 | 10:05 PM
RMP8080's Avatar
Question, I have a 87 Pickup 4X4 just install a 3 inch body lift and what's the best way to get the manual shifter working. I do not want to cut the floor unless that's the last straw.
Thanks, Bill
Old Mar 29, 2009 | 12:11 AM
Ed H.'s Avatar
use less body lift or cut and weld your shifter to make it work, only ways that i can think of.
Old Mar 30, 2009 | 04:31 AM
Trustyrusty's Avatar
Have a shop cut and weld 3" Extensions BEFORE the bends near the bases of your shifters, bend to fit as neccasary, easy.
Old Mar 30, 2009 | 06:06 AM
4Crawler's Avatar
Lots of options available:
- http://www.4crawler.com/4x4/ForSale/....shtml#Shifter
- http://www.4crawler.com/4x4/ForSale/...wShifter.shtml
- http://www.4crawler.com/4x4/CheapTri...orMountSpacers
Old Mar 30, 2009 | 09:29 PM
RMP8080's Avatar
Thanks to all, I'll extend the shifter that will look the best.
Bill
Old Mar 30, 2009 | 10:33 PM
toyNG's Avatar
extending the shifter might not help. It will move the top of your shifter 3 inches higher, or whatever height you order. But if your problem is limited movement of your shifter, the extender won't help at all. The reason is that the floorboard or center console is now moved 3 inches higher on your shifter. Consequently, the throw of your shifter is much more limited.
On my truck, the tranny shifter didn't give me any problems; it was the t-case shifter that I had to adjust. I inverted the boot, trimmed the metal plate that holds the boot, and slightly bended the shifter. It really wasn't too much work at all.
Old Mar 30, 2009 | 11:52 PM
Mic09dcsm's Avatar
Bill
Your kit should've come with the extensions.
Sep 4, 2015 09:27 AM
Poncho0206
Jul 10, 2015 06:21 PM
Yotoder865
Jul 9, 2015 07:51 PM
akaphilly
Jul 9, 2015 02:18 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
