Manual Transmission 3 inch Body lift
Question, I have a 87 Pickup 4X4 just install a 3 inch body lift and what's the best way to get the manual shifter working. I do not want to cut the floor unless that's the last straw.
Thanks, Bill
Thanks, Bill
extending the shifter might not help. It will move the top of your shifter 3 inches higher, or whatever height you order. But if your problem is limited movement of your shifter, the extender won't help at all. The reason is that the floorboard or center console is now moved 3 inches higher on your shifter. Consequently, the throw of your shifter is much more limited.
On my truck, the tranny shifter didn't give me any problems; it was the t-case shifter that I had to adjust. I inverted the boot, trimmed the metal plate that holds the boot, and slightly bended the shifter. It really wasn't too much work at all.
Sep 4, 2015 09:27 AM
Poncho0206
Jul 10, 2015 06:21 PM
FS[NorAtl]: 05+ tacoma leveling lift front MA
akaphilly
Jul 9, 2015 02:18 PM
