Pre 84 Trucks 1st gen pickups
High steer question ????
Old Mar 27, 2009 | 01:07 PM
Toyotoy's Avatar
Can i take the high steer out of any IFS toyota and bolt it in to an 80?
How does all this HS work?
thanks
Old Mar 27, 2009 | 01:14 PM
desertcamper67's Avatar
No you can't. It is completely different geometry altogether. The only thing I now of that you can use is the steering gear box.
The IFS has steering linkage that moves with the suspension travel therefore it has points where it will cycle as the control arm do.
On a solid axle you only have a big long tie rod conecting left to right. No movement is independent so the tie rod moves along the same path as the axle housing.
Hope that helps. Someone probably can shoot you a link or a killer High steer project.
God luck.
Old Mar 27, 2009 | 06:07 PM
dropzone's Avatar
Fossilized
YOu need about three inches of lift, high steer arms, an IFS steering box (86-94), an IFS box mount:
Originally Posted by waskillywabbit
The IFS box mount is pretty simple. Cut the fender well so you can easily access the PS box area like shown in my pictures posted already and then push the box all the way forward until it is on the core. Angle it so the holes line up on the frame in the center and then test fit your mounting plates. Tack weld and test fit again to make sure the pitman arm clears and weld out.
what you don't want to have happen when you install your high steer:
Originally Posted by 98taco4x
oh and make sure that your drag link clears your tierod.
Cause you don't want this.
it totally replaces the stock push pull system and places the tie rods up and over the springs..much better protection. also works well for flexy suspensions. I feel it is a well worth while mod. it will cost you about $400 -450 in parts unless you can find the stuff used. ($299 for high steer kit,$45 for mounting kit, $100 for IFS box)
stock steering:
afterwards with high steer:
kazuya2416
Apr 5, 2024 02:17 AM
glowz825
Jan 25, 2022 09:28 AM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
