Early Land Cruisers All solid front axles and Land Cruiser series - 25, 40, 45, 55, 60, 62, and 80
New mod (gps)
Old Sep 9, 2002 | 03:25 PM
RWD
New mod (gps)
I've always wanted a gps receiver for my 97 LX 450 and finally got one a few weeks ago. It's a Garmin V and so far I like it a lot. At first I mounted it next to the shifter but it was too low and hard to see. Also the stock antenna didn't work so great.
Old Sep 9, 2002 | 03:34 PM
RWD
I decided that I wanted it higher up so I mounted it to the trim piece on the inside roof that goes around the map light and sun roof controls. I used the standard Garmin mount but I flipped it upside down. I had to drill another hole for the retaining screw and do a little trimming with the Dremmel tool to make it fit. Garmin should really make a mount that is more universal so that it could be used upside down. I took the mount apart and drilled two holes through the base and used two small nuts and bolts going through the mount and trim piece. I also use a piece of heavy duty Velcro under the base for extra strength and to fill in the gap between the flat base and curved trim.
Old Sep 9, 2002 | 03:40 PM
Corey's Avatar
Co-Founder/Administrator
Looks very nice.
I need to upgrade some day and get a nicer GPS.
I have the original yellow E-trex that first came out a few years back.
Old Sep 9, 2002 | 03:43 PM
RWD
I also bought a remote antenna and mounted it to the a/c vent at the base of the windshield. The remote antenna works way better then the stock one BTW. It worked very good on the top of the truck when I tried it there but I could not figure out a way to run the antenna inside and make it look good without drilling a hole through sheet metal:eek: I settled for mounting it inside at the base of the windshield and works great so far. I ran the antenna wire behind the windshield rubber seal and it's completely hidden. The power wire is the same way going to the fuse box.
It took me about 3 hours for the entire job and I'm very happy with it. Very clean look! Bob
TheBFA
Feb 15, 2020 06:55 AM
voiddweller
53
Feb 1, 2016 05:46 AM
oldblue
Sep 28, 2015 04:07 PM
charlie_fong
Sep 27, 2015 10:06 PM
Project90
Sep 24, 2015 11:40 PM
