What do you guys think?
I'll say it before someone else does - Don't go out alone. (I know, sometimes ya gotta get away - I do it too.)
Anyway, the Wyeth-Scott is far superior to other come-alongs and a great addition to other tools. I wouldn't use it as a direct replacement for a winch, though. The line reach is the biggest issue - you've got about 15' to work with on the Wyeth-Scott, which is fine if you've got an anchor within 15' of your truck and don't need to be pulled very far. Any farther and you're limited to the lengths of the additional cables, straps or chains you've got with you.
A better option, although more expensive, are hand-winches like the Brano, Tirfor and Black Rat. Check out the Brano HERE.
A highlift jack can be used as a winch. Its time consuming though but will get your out of a bad situation . Works good with a snatch block. Also need various lengths of chain to make it usable.
It can also be used as a jack
Thanks, I think those are just what I was looking for!
polo451
13
Nov 20, 2016 07:49 PM
coffey50
Jul 28, 2015 10:55 AM
highonpottery
7
Jul 18, 2015 02:48 PM
