1990 Toyota 4x4 Idleing problem
I know that this has been covered a million times but im stumped. Just recently purchased a 1990 toyota 4x4 w/3.0 v6 and manual transmition.
I have owned it now for 2 weeks, I finaly had a chance to go wheeling with some friends, however when we returned the idle started to act wierd. Before it ran great, now it wont idle below 1300 rpm and when i apply the brakes the idle surges between 1400 and 1000. I have already tried burping the cooling system, the idle screw is turned all the way in, checked oil preasure, checked and rechecked all vacumme lines. any help would be appreciated
No water in engine, I did check the brake booster vacumme line it is fine, how do you test a brake booster? And i forgot to mention that sometimes when shifting the rpms shoot up yo around 3500
I'm kind of getting this info from a Chilton's repair manual.
To test for vacuum leaks:
1.operate the engine at idle for at least one minute without touching the brake pedal.
2.turn the engine off and wait one minute.
3.lightly pump the brakes several times. each time should produce less pedal travel, if vacuum is present. If no vacuum is present, ie a leak, then it will pump without much resistance.
To test for system operation:
1.Run it at idle for a few minutes. Turn it off.
2. lightly pump the brakes until all the vacuum is gone, ie, its difficult to pump the brakes.
3.start the engine, and operate it at idle. If the system is working correctly, the pedal should "fall" to the floor if constant pressure it applied to the pedal.
something like that...
I just cleaned my throttle body and my truck is doing the same thing.
Idles a little high after the cleaning (I was expecting that), but I wasn't expecting the idle to drop and surge when I press on the brake pettle.
I'll have to check my vacuum ports.
Cant get the base idle below 1300 before this happend i when it was running good i had checked the timing and it was on the money. Got idle screw all the way in and still 1300 rpm
check out this page on testing and cleaning the throttle body
http://www.ncttora.com/fsm/1993/engine/93throttle.pdf
Test your TPS out with a meter, it is really easy. I can walk you through it if you need. I just changed mine and it was an amazing improvement. If it is a vacuum problem, you will most likely feel it when accelerating, it feels like the engine stalling out or like there is a strong head wind.
you don't adjust the IAC (well, at least shouldn't- it was adjusted when it was installed on the throttle body).
For the most part, it either works or doesn't. You can, however, clean it.
