How do spring spacers add preload?
Old Feb 23, 2009 | 07:38 AM
LifeOnABoard's Avatar
Hi all. I'm new here. I've owned many vehicles but this 01' 4Runner is my first truck. This first thing I see wrong is that the rear is an inch lower than the front. So I do research and see that this is common and read about the options to correct. I'm inclined to go for spacers because I don't want to make the ride any more stiff. But apparently some users experienced accelerated spring fatigue with spacers. I won't question their experiences but I just don't see how this can happen. What is it about spacers that add load to the spring? It seems that they just raise the vehicle. Could there be other attributing factors that I am overlooking?
I would just like to add the $40 1.5" Daystar spacers to the rear. I don't want to replace the shocks because they seem to work well. I would also like to have a little forward rake. Are stock replacements a little longer?
I mainly use the 4runner for driving to work and up bumpy mountain passes.
Thanks for the help!
Old Feb 23, 2009 | 07:48 AM
mastacox's Avatar
If you put spacers on the spring but not on the bump stop, the spring can be compressed beyond its design limits accelerating spring fatigue.
Old Feb 23, 2009 | 08:02 AM
Gerdo's Avatar
True, but you also don't want to put the spacer between the conical bumpstop and the coil. This would not move the bumpstop away from the spring perch. I'm guessing that the BS is close to the perch now. (mine was about 1/4" away, it would hit on every bump)
Spacers on sagging springs are just a band aid. They will lift it but the spring is going to keep sagging. If you do spacers now you will be doing springs later.
Sounds like time for a lift.
The stiffness that you feel is probably from the suspension bottoming out and hitting the bumpstops. Mine was. Even with the Tundra TRD coils in front and Old Man Emu 891 coils (heavy duty) my 4runner has a better ride than before the lift.
Old Feb 23, 2009 | 08:11 AM
Ahhhhhh, OK. I can see how an extra bit of twist can hurt em. Now my next question, can stock shocks handle a 2" lift with slightly stiffer springs? The clock just turned 85K on mine.
Old Feb 23, 2009 | 03:37 PM
DavidAlexander's Avatar
If you are at 85k and doing a spring lift, you'll want new shocks. I have spacers with new shocks and would still not recommend them. I will be replacing them all when I can.
Old Feb 23, 2009 | 04:22 PM
Gerdo's Avatar
It probably is time for new shocks. Especialy if you are doing something with the front. Alot of people like the OME shocks with their coils.
Old Feb 24, 2009 | 05:01 PM
ehhhh, my mechanic specializes in trucks and only charges $40/hour. I think I'll just have him install the spacers and just do it right later if I don't like it.
justdifferentials
Just Differentials
14
Sep 24, 2017 08:32 PM
punks_is_4x4
May 31, 2016 06:03 AM
Jcrawl94
10
Oct 24, 2015 04:34 PM
_Nicco_
Sep 21, 2015 03:06 PM
terminator
Jul 27, 2015 07:13 PM
