A stutter problem gets worse
Old Feb 18, 2009 | 08:29 PM
tktmsa's Avatar
I've had a stutter during low rpm acceleration, and it was noticeable while idling as well.
I just changed the plugs-wires-cap and the stutter is a little more pronounced. Anyone else had this happen?
What else should I look at - Timing? fuel filter? Vac leak, O2?
Thanks
(94runner 3.0 5sp)
Old Feb 19, 2009 | 11:27 AM
86yota2wd's Avatar
I have that exact same problem with my 22R and i've done a complete tune up and a fuel filter. I can't figure it out either?
Old Feb 19, 2009 | 12:10 PM
okie81's Avatar
Start with timing and make sure you advances are working correctly.
Old Feb 19, 2009 | 12:14 PM
22mr2's Avatar
if you pull the plug wires off one at a time while running- it will help u find if you have a dead or weak cylinder. Its a quick check, compression check will tell you alot more.
Old Feb 19, 2009 | 03:32 PM
tktmsa's Avatar
Dang NGK wire came loose! So I monkeyd with the posts and got them all sitting tight and firm. Running much better now.
Old Feb 19, 2009 | 06:09 PM
okie81's Avatar
Good deal! It's great when the fix is that easy
young buck
18
Aug 27, 2018 02:40 PM
edoyle12
11
Mar 20, 2017 02:26 AM
GeoRoss
Jul 24, 2015 03:03 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
keithporter83
Jul 18, 2015 12:37 PM
