What is behind the driver's side wall in the cargo area?
Old Aug 28, 2003 | 07:45 PM
4RUNR's Avatar
Guest
Angry What is behind the driver's side wall in the cargo area?
After just finding out that under the passenger seat there's some air conditioning component, the idea of amp and sub under the seats can be scratched.
I absolutely can not have anything sitting in the cargo area. The amp will probably go under the driver seat, but where does the speaker go? Giving up the storage compartment isn't that fun of idea, plus it would not be too stealth if kept open.
What I was thinking is putting a 6.5" - 8" inside the rear wall? Color match the grille and it should be invisible.
Old Aug 28, 2003 | 07:47 PM
L33T35T 4Runner's Avatar
ive seen people put one in the storage compartment in the rear passanger side.
Old Aug 29, 2003 | 05:20 AM
4RUNR's Avatar
Guest
But that's the ONLY place in this car to store stuff
Old Aug 29, 2003 | 05:22 AM
phoenix808's Avatar
q-logic makes prefab boxes, crutchfield (overpriced) has them at http://www.crutchfield.com/cgi-bin/S...=0&cc=01&avf=N
hope this helps!
brian
Old Aug 29, 2003 | 05:34 AM
SLC Punk's Avatar
The gas tank filler neck is behind the cargo wall on the driver side. I don't know how much room would be back there though.
Old Aug 29, 2003 | 09:06 AM
4RUNR's Avatar
Guest
Any tips/tricks to pull the panel back slightly and look?
Old Aug 29, 2003 | 09:13 AM
Bob_98SR5's Avatar
4RURN,
They are held down by snap rivets but you'll have to unscrew some trim pieces to do that:
http://www.4runners.org/articles/sound
Bob
Old Aug 29, 2003 | 11:08 AM
Paul H.'s Avatar
I have my cd changer there. Had to cut an opening large enough for it though.
Old Aug 29, 2003 | 12:46 PM
4RUNR's Avatar
Guest
While measuring the place in the wall - it hit me! WHAT ABOUT THE REAR SWING UP DOOR!
It looks like it could easily hold a pair of 8" subs! And talk about unobtrusive and stealth! Would be a Houdini act to feed the wires through stock locations, but otherwise look like the perfect solution.
Bob that's an awesome page! Ever try removing the 5th door panel?
Old Aug 29, 2003 | 12:55 PM
MTL_4runner's Avatar
Do you use your rear window at all?.......not after that mod.....
Old Aug 29, 2003 | 01:23 PM
4RUNR's Avatar
Guest
Hmm! Yah that would suck. But it does look like the glass will clear a pair of 6.5" surface mounted subs! If only I could take it off and be sure.
Old Aug 29, 2003 | 01:29 PM
Bob_98SR5's Avatar
4RUNR,
Yeah i may get to that last 5th tailgate door but its already library quiet back there.
Bob
Old Aug 29, 2003 | 02:13 PM
4RUNR's Avatar
Guest
Well, the tailgate idea can be scratched too. After taking off the panels, it's so tight in there.... well nevermind
Guess driver side wall it is
Old Aug 30, 2003 | 05:45 PM
4RUNR's Avatar
Guest
The deed is done! Pair 6.5" subs with an uber infinite baffle setup. The bass output and quality can be equited to a pretty good stock premium system in a luxo sedan. Doesn't go too low, but adds so much as it's coupled directly to the body. (~45hz) Surprisingly the plastic panel that goes over them did not change the sound one bit.
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
CanRunner
Jul 20, 2015 01:29 PM
rushw
Jul 18, 2015 01:46 PM
coryc85
Jul 6, 2015 04:07 AM
