Has anyone used a procomp 3inch suspenion lift?
i picked up the front half of the kit, the problem im missing the install instructions, that and i would look to make sure i have all the parts anyone have any experience with this kit? or know where i might be able to get the instructions, pro comps web site does not have them.
looks like they came off a SAS vehicle....
okay, let's start with the last pic:
top left- right front suspension knuckle extension
top right- left front suspension knuckle extension
bottom are transmission drop brackets and bushings- IIRC, the one on the left is on the right side of the vehicle and the one on the right goes on the left.
You would wait til today to post this...
. I'm in Mason, not terribly far from you and could've came over today and helped lay it all out. Maybe if I'm not working tomorrow we can work something out. It's just going to be difficult to explain in the forums because you have some bolts and stuff you won't need.
And FYI- I have the same basic kit on my 88 (in my avatar). Your's is a 4" lift, Stage 1.
Did you get the blocks for the rear with it too?
no blocks, what happened is i was in a rear end collisions and both my rearend springs are toast, so im planning on ordering new lift spring from downey offroad, since i have to replace the parts any way, i figured why not use a little lift
justdifferentials
Sep 5, 2015 06:52 PM
joeynational
Sep 5, 2015 01:54 PM
