My 86 Manual Swap ->
Not sure where to put this, but here it goes
Project: Swapping a manual transmission in for an automatic in a 1986 Toyota pickup with a 22re
I started with this truck because I picked it up for $500 with a 22re and running and somewhat drives.
Then, I picked up this g54 tranny from a 22r (yes, there is difference, but shouldn't matter!) for $100 w/ a fork, but missing shifter and output shaft yoke
Here is the output shaft "yoke" as the dealership calls it. Mine was missing. So $65 more...
Shifter, $5 from the junkyard
Forward shift T-case. If your using a W-series tranny then DON'T get a forward shift transfercase...you will need a top shift. $50
Cross-member, I was told they were different between auto/manuals, but look identical. $15
Flywheel, $15 + $30 for resurfacing so $45
Pedals, you obviously need pedals because you need a clutch
$25
Clutch kit, $90
Clutch slave cylinder, $11.50
Okay, thats about all the parts besides a few I am missing.
Now, removing the tranny + transfer case. I thought it would be easiest to drain the fluid first, and to drop everything out at the same time.
First, I removed a couple bolts from the x-member
Then, I took off the shifter
Next, came off front + rear driveshafts
Next, I secured the whole transmission assembly with a transmission jack. That way it would put less stress on the bolts and therefore making it easier to remove.
There goes the hood!
Okay, next, I started removing all the bolts around the tranny. That way I could get it out of there. The hardest bolts were the top 2 on the back of the engine. One took approx. 30 mins. and the other took about 1 and 1/2 minutes. Here is what I used...
Next, grille and tranny cooler.
Next, I removed all the lines or anything attaching to the tranny.
And started pulling it out.
Now its OUT!!!
Money spent so far:
1) Tranny $100
2) T-case $60
3) Flywheel $55
4) Pedals $20
5) x-member $15
6) Tranny seal $4
7) Tranny output $65
8) Clutch $90
9) Clutch master $38
10) Clutch slave $25
11) Shifter $5
NEXT, 5-spd tranny goes in.......
PART 2
Back of the engine
New vs old flywheel
You'll need longer bolts for the flywheel...
Flywheel on
Clutch disc
Pressure plate on...
Tranny + t-case almost about to go in...
Getting closer
Trying to get it to fit
ITS IN!!!!!!!!
Connected drive-lines
Cut hole for shifter
next, installed clutch master cylinder, slave cylinder, lines, and pedals
Next, I jumped two wires near the passenger side wheel well. It needed to be jumped so the computer thinks the truck is in neutral so it will start. No pics...sorry (its got 3 wires and its white, you jump the bigger of the two!)
I hooked up my speedo line
DONE!!!!!
$25
Clutch kit, $90
Now its OUT!!!
Money spent so far:
1) Tranny $100
2) T-case $60
3) Flywheel $55
4) Pedals $20
5) x-member $15
6) Tranny seal $4
8) Clutch $90
11) Shifter $5
PART 2
Back of the engine
New vs old flywheel
Flywheel on
Clutch disc
Getting closer
ITS IN!!!!!!!!
DONE!!!!!
nice...you will love the 5spd over the dogmatic...i did my swap in over a weekend..the auto was out firday night after i got home from work, and the 5spd was in and finished by midday sunday...the swap dosen't really take long so long as you have all the parts...good luck
Thanks, now I need some flywheel/pressure plate bolts so I can put it together in the next couple days. I don't feel like waiting a couple weeks on some little bolts from the dealership.
I was told the auto tranny's t-case was a chain driven t-case and the t-case's behind manuals are gear driven...so no. lol
Thanks for the writeup
So you re-used the auto driveshafts? Did you have to cut a hole in the firewall for the master cylinder?
For the clutch master cylinder, I had first marked the area of where it should be, then I drilled a hole with the biggest drill bit I could. I then used a chisel (sp?) to punch out the hole so it was bigger. It is nice and secure and doesn't move. But I suggest buying a big drill bit, as I didn't have a big drill bit or drill.
And yes, I re-used the driveshafts. They both fit just fine. They seem to be in the exact location.
Are you thinking of the swap?
No problem.
I find it interesting that Toyota actually made two different cabs for auto and manual. I see you had to cut out for the shifter, and I noticed that I would also need to cut out for the master cylinder. Does the pedal assembly bolt up, or was there some fab work in that involved?
Oh, I'm more than thinking about the swap, it's happening as soon as it warms up around here. I'm just trying to make a parts list. Guess I can take driveshafts off of it
Anyway, the pedal assembly was straight forward. You actually get to keep your gas pedal and believe it or not but the pedal assembly has a mount for the clutch pedal already. All you need is the pedal, the spring, and the bolt that goes through the pedal. And you also need the brake pedal because it is smaller and shaped differently. The mount to the truck is the EXACT same, the pedals are different.
The only thing that I currently do not know about the clutch pedal is whether or not there is another spring attached to the pedal, because it is the softest clutch I've ever felt. But works really well.
I definitely recommend this swap. Having a manual tranny is a whole new world.
