sr5 cluster into 93 pickup
Old Jan 25, 2009 | 07:07 AM
yotagon400's Avatar
hey ppls im stuck i need help .... well wat im doin is tryin to put a 92 four runner cluster in a 93 pickp and all the clips plug and play and the mile per hour work and fuel temp and odometer work and im tryin to figure out where to place the wire and which clip in cluster does the rmp signal wire goes any info will help thanks
Old Jan 25, 2009 | 10:07 AM
yotagon400's Avatar
bump need help
Old Jan 25, 2009 | 11:00 AM
cadman's Avatar
You need the combination meter wiring diagrams for each vehicle to see what goes where. I have them for the '93 truck and '91 4Runner but they are too large to upload here. PM me an e-mail address and I'll send them to you.
Old Jan 25, 2009 | 01:14 PM
yotagon400's Avatar
bump...
Old Jan 25, 2009 | 02:07 PM
Flash319's Avatar
Did the dash that you pulled out have the tach? If not the wire harness probebly does not have that wire in it. I had to go through this with the diesel install. I had to run the wire to the proper pin. Number 7 on the connector closest to the drivers door.
Old Jan 25, 2009 | 02:55 PM
cadman's Avatar
pdfs sent.
Old Jan 26, 2009 | 05:08 AM
yotagon400's Avatar
thanks cadman i got it ... but no my old cluster did not have a tach on it before ... but do i have to run a wire from the coil to the #7 pin on the clip or do you have to combine wires to make it work
Old Jan 26, 2009 | 05:35 AM
cadman's Avatar
yotagon400,
The pdf for the '93 truck should also have the wiring diagram for the cluster without the tach, but yes, all you need to do is run a single wire from the igniter to the tach pin on the cluster.
Old Jan 26, 2009 | 06:59 PM
cadman's Avatar
One more thing you need to change. If your stock gauge has the low oil pressure warning light and the new gauge has the oil pressure gauge, you'll need to remove the oil pressure switch and replace it with an oil pressure sender.
Old Jan 26, 2009 | 07:03 PM
DeathCougar's Avatar
My 86 already had the wire built in.
I can't imagine that the 93 doesn't have it. Your first post was confusing, did you plug it in and the tach doesn't work? Did you match v6 to v6 or 4cyl to 4cyl? They have different tachs.
Old Jan 26, 2009 | 08:30 PM
cadman's Avatar
Sounds like his truck is the DLX model like mine (no tach, oil pressure gauge, voltmeter, etc..)
Old Jan 26, 2009 | 08:43 PM
toyota4x4907's Avatar
Are you saying DLX didnt have those? I'm pretty sure they were an option, if you didn't know. my '93 DLX had tach, oil pressure, and voltmeter...
Old Jan 26, 2009 | 08:55 PM
cadman's Avatar
My DLX did not have the cluster with the tach, oil pressure gauge, voltmeter, or reserve light. That was probably an option on models with manual trannys, autos don't really need a tach. The Toyota FSM shows both clusters in the Body Electrical section. I personally think the DLX cluster looks better, but I wanted all of those dodads.
Old Jan 27, 2009 | 03:53 AM
yotagon400's Avatar
ok sry if i confused you guys but i have a 4cyl and my old cluster did have the oil press,volt,or a tach. all it have was the temp fuel and speed, and the new cluster that i purchased has all those gauges and i plugged it in and theonly thing that works is the speed, fuel , temp , and volt , and im tryin to figure out how to make the rpm to work and wat wires to connect
Old Jan 27, 2009 | 06:37 AM
Flash319's Avatar
You have the same that I had. V6 auto gauge package, all dummy lights and a speedo. Everything was there for the other gauges just not the tach wire.
Old Jan 27, 2009 | 08:56 AM
cadman's Avatar
Search and you shall receive. I knew there was an early writeup somewhere:
https://www.yotatech.com/forums/f115...ictures-51800/
Read the entire thread.
Old Aug 17, 2010 | 07:25 AM
Leethaxor4u's Avatar
yotagon400,
7 wires come out of the ignitor, which do I spice into?
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
crashburnoveride
Aug 28, 2015 09:20 PM
Cplmike
Jul 8, 2015 08:47 PM
raiderhawks00
Jul 8, 2015 06:23 PM
