4Banger Vs. v6 Prerunner. NEED ADVICE
I was wondering if there was a dramatic power difference between the 4cyl and the v6 prerunner 2wd, auto's, xtra cab.
Does the 4cyl lack in power??
is the gas mileage better??
does the engine last as long as the v6?
Any gripes or concerns???
Thanks
Thanks
I have the 2.7l and it has plenty of power for me. As long as you get it in a 5speed it should be fine. They are great little engines and you don't have to worry about the cam belt needing to be changed because it is a chain.
but then u gotta worry bout the chain breaking and causing all kinds of mischief...
I would personally get the 3.4, the 2.7 is ok and it is relible but the 3.4 has a lot more power and is just as relible (i have seen these engines go over 350k miles 100% stock and with nothing but normal work).
Plus you will never regret having more power but you could very well regret having too little (forget about towing with a 2.7)
As said, don't even think about the 2.7 unless it is a manual tranny.
My dads 99 2.7 5speed. 4k pounds=trailor + yaris, Not to mention the 10+ guitars and 3 amps all in the back of the runner....
Ok, i should clairfy, you CAN tow but it is not an enjoyable experiance.
Heck i have seen little 4 bangers loaded down with more weight then a full sized truck and move it from point a to point b, doesn't mean it is safe or easy lol.
ashamsuddin
17
Jul 22, 2024 03:59 AM
calguy248
9
Nov 23, 2010 10:30 PM
JeepDefector
Sep 27, 2007 10:41 AM
bocephas70
10
May 6, 2004 07:44 PM
