BJ spacer, wheel/tire set up
Old Jan 6, 2009 | 09:05 PM
pathfinder's Avatar
I know this has been discussed but I can't find any threads that come close to answering the question of what back spacing is needed for different wheel/tire combo's when running a 1.5 BJ spacer. I've got a '90 pick up and I'm thinking of going to a 16 or 17" wheel. From looking at pics it seems that stepping up wheel size may allow a little more space with the UCA, most notably the 17", if I stick with with a 7 to 9" wide rim and say a 11.5 or smaller width tire as the the larger wheel places the wheel lip closer to the UCA as opposed to the tire.
Another reason for the the 16 or 17 inch wheel is that I'd like to run a set of Nitto Terra Grapplers...heard some very good reviews and they're priced well...and I like to be different!
P.S. I'd like to avoid a wheel spacer.
Thoughts on the larger wheel theory please!
Old Jan 6, 2009 | 09:19 PM
Matt16's Avatar
I'll take a better look tmr, but its going to be tight, that said, I was able to run front tire chains without issue.
Old Jan 6, 2009 | 09:23 PM
scuba's Avatar
When I put on my Bj spacers on my 91 p/u, The UCA was hella close, I even bought wheel spacers to slove the issue, Then I said, Well Since im already in here with this angle grinder, why not grind down the UCA to where it doesnt rub, Problem solved...
Old Jan 6, 2009 | 11:14 PM
Matt16's Avatar
The lip is smaller than it appears, and it adds strength to the a-arm. I think 1/4" wheel spacers would be a better bet.
Old Jan 6, 2009 | 11:23 PM
scuba's Avatar
O i know matt, I ground it down, then some...but yea, 1/4 to 1/2 depending on what wheels and tires, I just went full out with 1.5"
Old Jan 7, 2009 | 01:23 AM
Matt16's Avatar
That 1.5" spacer directly contributes to the length of the level arm on the t-bars. Translation: your IFS should flex better using wheel spacers than ball joint spacers!! Wheel spacers don't add to wheel travel, but it would increase the tendency of the IFS to flex.
...now back to watching a Beautiful Mind.
Sep 4, 2015 09:27 AM
Peevedkitten
11
Aug 31, 2015 06:57 PM
punks_is_4x4
Aug 21, 2015 01:35 PM
Luvmeye22re
Aug 4, 2015 03:53 PM
terminator
Jul 27, 2015 07:13 PM
