Towing 4runner cross country
Hi guys,
I'm looking at the possibiity of towning my '98 4runner, v6 automatic, across country within the next couple of months.
My question to you is this; if I use a tow dolly and tow the runner in a forward direction with the front wheels up on the dolly and the back tires on the ground and put the transfer case in neutral and the transmission in park will I be okay with the rear dirveline in place or should I remove it?
Thanks,
Brian
Thanks,
Brian
REMOVE IT..only 8 bolts .. its ok if your going like 30minutes to an hour away but cross country not worth ruining your tranny!
i tow my 4runner with my hilux all the time on a dolly... its stick though... long trips i remove driveshaft
Alright guys,
If I pull the driveshag in preparation, will I be able to drive the vehicle up on the tow dolly in front wheel drive? Will I lose a ton of Tranny fluid from the back of the output shaft housing when I do that?
Thanks again,
Thanks again,
hrmmm you should be able to drive upon the tow dolly.. but if you keep it connected then drive on the dolly the truck will be JACKED UP so it would be easyier to get at the rear shaft...
you can just disconnect it from the rear diff and zip tie it up out of the way!
BeMiceElf
Oct 10, 2015 09:40 PM
Sep 4, 2015 09:27 AM
skoti89
Jul 6, 2015 07:45 PM
