Oil consumption-no smoke, good vacuum ??!?
I posted a while back about a newly rebuilt 22re in my 91 pickup burning a little oil. I thought it might be a ring seating issue, well now i have 2000 miles on the motor, and i am going through a quart every week and a half, no smoke , no fouling on plugs, good steady vacuum, and no oil leaks or oil in coolant. I am stumped. I have seen honda's that billow smoke from the exhaust, and have every symptom of bore damage/worn rings that use less oil than this truck. I am super frustrated and am thinking about buying an LC motor. Any suggestions from you guys before I buy a new motor/rebuild this one? Thanks in advance,
Rad
Rad
I am switching to a motorcycle oil tommorrow as you suggested in another thread, abecedarian. I didn't rebuild this sucker so I can't comment on how the rings were clocked, or what type of rings were used. but I will do a compression test tomorrow after changing oil and let you know the results.
I am an acura mechanic, so this truck goes on a lift at least once a week, I'd have seen a leak, and I'd think there would be some smokle on startup after sitting if the guides were leaking. I changed out the oil with some 30w compressor oil, to rule out rings seating. Like I said, the weird thing is the lack of symptoms other than low oil level. But thank God for Yotatech I really appreciate the time you all are taking to put our heads together to figure this issue out. BTW, the cat is still on this truck BigBlock.
i know 91toyota had an simular thread recently and he pretty much determined that he got tapered rings and probably installed some of them upside down. but i think he said he was getting a little bit of startup smoke. hopefully that is not the issue with you. like previously stated if you got chromolly rings they take a long time to seat.
I put 30W ND in it today, I'll leave that in for about 500 miles and switch over to a good multi weight and see what happens, I need to do a compression test, meant to do one today, but got hung up with "honey-do's"
Sep 4, 2015 09:27 AM
TokyoD23
Jul 12, 2015 06:01 AM
