315/75/16 Maxxis Bighorns on my 98 4Runner
i found these on craigs list...
Hunters Special.. 4- Maxis brand LT315/75R/16 Tires. Mud Grip 65% Tread, Rotation marked. $200.
[IMG]
[/IMG]
i have 255/85/16 now on a 16x7 soft 8 wheel with about 3" of lift and no rub. i was going to buy the Maxxis Bighorn in a 285/75/16 new for $650 but found these tires for $200. just worried about that much tire on a 7" wheel.
255/85/16 = 33 x 10.5
315/75/16 = 34.5 x 12
what do you guys think of this tire on my 4runner? i have read that others have run this size with no problems on 7" rims.
bring on the thoughts and comments.....im going to pick them up tonight..
here is a pic of how the 4runner sits now with the 255/85/16...
[IMG]
[/IMG]
[IMG]
[/IMG]i have 255/85/16 now on a 16x7 soft 8 wheel with about 3" of lift and no rub. i was going to buy the Maxxis Bighorn in a 285/75/16 new for $650 but found these tires for $200. just worried about that much tire on a 7" wheel.
[IMG]
[/IMG]
i always heard that 8" was the narrowest wheel for a 12 inch tire. and thats a 34.5x12.50. lot bigger than a 33x10.00.
http://procomptires.com/conversionchart.htm
im sure if they dont fit that you could re-sell them for what you have in them though.
your 4Runner looks great btw. what kind of lift are you running?
im just running a spacer lift for now....i know, i know.
the lift is a front top out of the coil pack 1 5/8 " spacer and the rear is a 3" poly spacer. this gave me at least 3" all around...clears the 255/85 with no problems at all...no trimming.
[IMG]
[/IMG]
i have the 882 coils, waiting to put on when i get the 1" BL. just hope these will fit untill then.
[IMG]
[/IMG]i have the 882 coils, waiting to put on when i get the 1" BL. just hope these will fit untill then.
i would suggest the 883's. i have them and they ride great and give just enough lift that i ran the 35's with body lift. on the street they didn't rub at all but offroad the would barley kiss the pinchweld.
and i would get the longer land cruiser coils for the rear if you get the 883's and if you stick with the 882's i would suggest the shorter land cruiser coils.
here is a picture of mine with the 883's and the toytec top out spacer with the longer land cruiser coils in the rear and 315's...
bobby
bobby
i just got back from picking up the tires. they look great!!! i measured them and off the rim they are 33.5" with 50-60% tread. the fronts have a little cupping but will put those in the rear. we will see how they fit in the am.
tires are mounted....
had to trim just a little off the front valance and the pinch weld. i will have to have the my 882,s with the top out spacer installed to do any kind of wheeling...for the street it is now what we call a pavement pounder....
[IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG]
