how hard is it to bend a rear axle?
Your axle is definitely NOT bent. I don't think it is possible to even drive normally with a bent rear axle...lol
Isn't it too much toe-in? Or something like that. Not sure if it can be adjusted or not (doubt it)
Good luck!
Good luck!
haha it is possoble to drive with a bent axle because my dads tacoma had a badly bent inner axle and it drove normal, didnt shake at all but we would have people oftenly tell us to stop because our wheel is going to fall off...
bending both the axles and the housing requires high amounts of torque... it is possible tho, but i imagine that a bent axle or housing would be incredible obvious to you...
maybe the wheel bearings?
dang you abe... you beat me!!
I think bending the housing would take a lot of force, but bending the semi-floating axle shafts is not too hard. I have 6 of them all bent to one degree or another. However, that won't cause that sort of tire wear. Rather it makes the rear wheel wobble and you can feel a little vibration from the rear end at speed. Mine is not too bad unless both bent axle shafts get into phase and the wobbles combine, then it is very noticeable.
Cubuff4Runner bent a rear 96 4Runner E-locked rear housing this summer. He ended up swapping to an IFS rear axle and converted it to a full floater. IFS housing are way cheaper to replace than the E-locker housing
He really didn't come down that hard on it. His rig probably weighs over 5K though
You can run drive flanges but he chose to run stock Aisin hubs from a solid axle. The full floater kit works great and changing rear shafts or pulling a 3rd member is nice and easy!
if it were not possible to bend one, would people have been welding gussets to them for decades now?
it's possible, but unless you're bashing the thing against rocks, or jumping it, I highly doubt that the axle housing, or one both of the axel shafts for that matter, are bent. more than likely wheel or axel bearings as mentioned already...
Axle truss?
Years ago (yeah I'm old) a lot of 4wheeler put axle trusses on there 4x4's, I never understood what they where doing to there trucks that could posiibly bend an axle housing. I tried and tried with my 74 K5 Blazer, I bent rims, shreded sheet metal but no matter how hard I tried they wouldn't bend.
jerusry
Oct 19, 2015 05:28 PM
Iceman4193
Jul 15, 2015 04:48 PM
toyoda8488
Jul 5, 2015 10:18 PM
