Downey Torsion Bars
Yes you can get spacers for 2wds.
Here's the deal with torsion bars. You get stiffer torsion bars for the same reason you get stiffer leaf or coil springs, you want less flex. If you want to carry a heavy load in your truck all the time, you need springs that flex less right? Of course. Well since IFS is not terribly flexy suspension as it is, putting in a stiffer spring only makes it worse. Downey's torsion bars are about the stiffest there are.
You might consider them if you have a heavy winch/bumper combo or like to do the desert thing. In both cases the loads are a lot higher and a stiffer spring can help.
You can read up here.
Frank
Frank
Frank
Frank
Is SDORI your site?
I see you sell ball joint spacers
hm..I thought you got thicker t-bars so you can "un-crank" them to get better flex
or just put them in there so they make the ride higher but sacrifice ride quality like you said.....
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
choppe777
May 16, 2016 08:00 AM
WTB[PacNorWest]: Old Man Emu Torison Bars
A2theK
Oct 14, 2015 07:10 AM
FS[SouthEast]: Brand new 26 mm. Downey torsion bars
HiLuxer
Sep 9, 2015 02:43 PM
