Where to set idle and timing on 22R?
Old Oct 31, 2008 | 04:30 PM
Asha'man's Avatar
I bought another truck a couple weeks ago, an '85 xtra cab 2wd pickup. My parents' neighbor put a new head on it last summer but never readjusted the valves, so it idled around 1200rpm and clattered like a popcorn popper. I adjusted the valves and turned the timing down at CoTTORA's S HOW a couple weekends ago, and it sounds a lot better. However, it idles extremely low and runs rough at idle, so I tuned it up just enough by ear so it was slightly better. I still need to dial it in again with a digital timing light.
What do you all have your 22R's set at as far as base timing? The underhood sticker says 700rpm and 0* base, but when we had it set there it wouldn't run worth a damn. I'm thinking closer to 900rpm for idle speed, but don't know where I should set the base timing.
Old Oct 31, 2008 | 04:50 PM
abecedarian's Avatar
may need to adjust the fuel mix too to get it idling right at 700.
Old Oct 31, 2008 | 06:10 PM
Asha'man's Avatar
There's no fuel mix screw on an '85 carb. I looked, and the books confirm.
Old Oct 31, 2008 | 06:25 PM
yeah, guess you're right. >grin< you can check the float level though.
you're checking the timing with the dist vacuum lines unplugged and blocked?
shouldn't need an adjustable light to set it to 0.
Old Nov 3, 2008 | 03:28 PM
Asha'man's Avatar
I didn't have a light of any kind, hence the adjustable. Plus it has a tach and my truck doesn't, so that kinda helps a little when setting the idle speed. In any event, I set it to 0* base with the vac lines off and plugged, and set the idle to 900rpms. Runs a lot smoother now, will see if I get better mileage. If I do, I may take it in for emissions the way it sits and see what happens.
sonic concepts
Aug 16, 2025 03:13 PM
Ichneumon
Sep 27, 2015 04:21 PM
thelifeadventure
Jul 2, 2015 03:09 PM
83flatt
Jul 2, 2015 10:30 AM
Alex Bessinger
Jun 28, 2015 10:05 AM
