New to the forum, need advice
Hey fellas,
I am new to Toyotas (coming from Audis), and recently bought an '86 4Runner to use as a daily driver as well as my hunting truck. So far, I think it's great! I'm excited to put it to the test off-road. My grandfather always used to say that those Toyotas will go ANYWHERE. I guess I'll find out
I used to drive my FIL's '85 Camry, which has a clutch fluid leak, and I'd have to refill the reservoir once every couple weeks. Well, this truck seems to have the same problem, except that I have to refill it twice a week! The fluid seems to be dripping down the left side footwell. I'm thinking that it's probably the clutch master cylinder, but these Toyota systems are all new to me!
Anybody have any ideas of where it might be leaking from? If it's the master cylinder, which part of it typically leaks? What's required to replace it?
Jordan
Jordan
Hey fellas,
Jordan
Jordan
http://www.marlincrawler.com/htm/transmission/clutch.htm
Thanks fellas,
So I assume you just unclip the MC from the clutch pedal in the cab, then unbolt the MC from the firewall under the hood and slide it out? Is there some trick I should know about?
Thanks again!
Thanks again!
The clutch master cylinder usually leaks inside the car onto the carpet. that's why you don't ever see any fluid. Feel around the floorboard carpet under your clutch pedal and I'll bet you'll find your leak.
The front seal is the part that leaks - between the body and the pushrod (non-pressure side). It's a wear item, nobody's fault. Other than adding that it must be bled out, it's exactly as you described. Nothing hard about it.
jasonty
41
Dec 23, 2018 01:00 PM
britishdudes2dr
Jul 25, 2015 06:47 AM
MTLroadierunner
Jul 20, 2015 03:07 PM
