What's the best way to reinforce this?
As you can see, this is pretty fu-barred!
I was thinking about just getting some 2'' angle iron, but its not quite long enough. 2 1/2'' would probably work better, IF I can even find any around here!
Also, I've seen/heard other people reinforcing this front 'cross member'(?) before, but I've also heard someone say that if you just cover up the holes, it might cause the engine to over-heat because those holes allow air flow to the radiator.
Help??? Ideas??? Thoughts???
i don't see a pic??
but i think i know what your talking about.
angle iron will work good, or just plate it all with flat stock and weld all the seams. i think those holes were in the cross-member are there to reduce weight. Ive had them stuffed full of mud many a times. never caused me to overheat!
ummm wow that's bad... A piece of boxed steel would work ok I guess.
Another thought is to take a old bolt on trailer hitch mount cut it and weld it in there.
That way you have a recovery point with a class III hitch.
Then you could throw a multi mount winch right in there.
I wouldn't worry too much about air flow to the radiator. People do it all the time and it's fine.
noodle
Mar 2, 2005 12:23 PM
