bleeding brakes/LSPV
When bleeding the brakes, I know you start with the farthest away from the master cylinder, but where does the LSPV fall into that process? Should it be done before the rear brakes, after the passengers side rear, etc?
Thanks.
Thanks.
Per the FSM: LeftRear, RightRear, RightFront, LeftFront, LSPV since it connects the front and rear brake systems.
Although I often do the LSPV after the right rear since I am there and have my vacuum brake bleeder all set up.
