Rear OME Question - one side lower then the other
Old Aug 10, 2003 | 11:22 AM
Roadrunner's Avatar
I noticed last night that the rear passenger side OME is about 1" lower then the rear driver side. Can I use the Front 5mm coil spacers, Part# - OME95PF5 on the rear OME to level it out? Didn't see anything marketed for the rear OMEs. If not, other suggestions please. Thanks.
Old Aug 10, 2003 | 12:36 PM
White SR5's Avatar
What you did
What you probably did is install the left-hand spring on the right side and the right-hand spring on the left side. I did that one... silly me. The driver's side spring is a touch longer than the passenger side one to compensate for the gas tank and 4WD stuff. If you're sure you did them right, I don't know what to tell you.
Zach
Old Aug 10, 2003 | 12:49 PM
turboale's Avatar
There is the stuff zach mentioned, also my boss (who is a crazy BMW enthusiest) told me that the M3s are slightly taller on the left side and are designed for a 170lb driver. Just a thought...
Old Aug 10, 2003 | 01:31 PM
TDiddy's Avatar
Zach is right, the taller spring has to go on the gas tank side. If the springs are in there correctly already though, there are rear-specific trim packers. The fronts will not work on the rears.
You can get them from Mike @ Xtreme Off-Road.
Old Aug 10, 2003 | 04:05 PM
Roadrunner's Avatar
Thanks for the input. I'll have my wife get the measurements while I sit in the 4Runner, maybe they'll be close to even with me in it.
Old Aug 10, 2003 | 05:13 PM
Paul H.'s Avatar
I noticed that mine were put in wrong too but the left and right are even. Go figure.
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
Vargntucson
Jul 4, 2015 12:15 PM
