4 lights across stock bumper.
I've been looking around for a while but I'm not finding any pics of a 3rd Gen with 4 off-road lights across the top of a stock front bumper. I was playing with Photoshop and I wasn't sure I liked the look. I would like to have two on top and then two lower down where the lic plate gets bolted on. But I'm not sure about the idea of bolting lights to nothing but plastic with a lic. plate lightbar type mount.
So if anyone has any pics to show me or ideas, I would love to see them. I don't want to spend money on a bull bar or brush guard because I would like to replace the whole bumper someday.
I like the second. However, even mounted on top of the bumper, you'll experience a certain amount of vibration in the lights. The only answer for that is a light bar that is tied into the frame somehow.
That set up sounds good in theory but there are a few issues.
First off.........that pesky plastic filler panel on top of the bumper.
Then there's the blocking of the radiator and tranny cooler.
Most of the front end is plastic so attachment points are few.
Some buddies have those hoop bars but if they are not installed correctly..
good god.......they wiggle, shake, shimmy, crack and vibrate all the hardware loose..
Good luck...Kenny S>
I'm brainstorming how I can make a bracket that will bolt to the top of the bumper (in front of the plastic cap) and roll down towards where the lic plate is mounted. Then have the lights mounted to it. Maybe some extra metal under the top part of the bumper to help support them as well.... I don't know... I'm just in the thinking stages of this. I haven't even got the lights priced out yet. (made calls, no answers yet)
My front bumper is all metal, so i just drilled straight into that, so if you have metal underneath it you should be good to go.
Honestly, I don't have to HAVE 4 of them, but I would LIKE 4 of them. If I used only 2, I "could" use the dark blue lenses for winter time, then change to yellow for the rest of the year. Amber if I plan on off-road trips or camping... Hell, I could even change to the inferred ones when I wanted to play Army...
LOL
Good luck with that, you need to find a rheostat that can handle the full load of those lights, since your gonna have to install it on the back side of the relay.
Why not break the bank and get an xmitter light bar.
http://www.visionxoffroad.com/products/led/XmitterBar/
If anyone cares about reading up on these:
http://www.lightforceusa.com/images/...webversion.pdf
That would solve all my issues, and they are bright as a mofo. But just the mounting issue with them.
Lights installed! (PICS)
Got the lights installed. I haven't had time to make any kind of bracket to have two lower down on the bumper so I just mounted all four across the top. Also, because of one broken headlight I ordered the black headlight set and got those installed as well. I think they came out pretty good.
I have the LightForce hooked up on a three way switch (one switch for each set of lights). One of the "On" is wired up to my brights. The other is hooked to a ign. source. When winter comes I'll change over from the yellow lenses to dark blue to see better in the snow.
What do you think?
What do you think?
Pretty sweet, I too was one of those "wierdos" who wanted 4 lights on my truck, except on a light bar, it's kind of a sickness I'm putting 4 more on the truck but oh well. Oh and do the colored lenses really work?
[/IMG]
