85 frame swap
Old Aug 20, 2008 | 07:38 PM
90YotaPickup's Avatar
85 frame swap
ok fellers im doing a frame swap on an 85 toyota pickup i just wanted to show you guys what im doing and my truck this is my first time having a pickup this far tore down
this is what i started out with 600 dollars knowing the frame was rotten but i thought i could fix it turns out its too far gone so i did some searching around and found a non rotted frame from a place in pennsylvania called weikles specialty (i highly recommend them if your in pennsylvania they take care of you and they have there own yota junkyard)
wire wheeled primered and painted gloss black rust oleum oil based enamel its purdy looking lol i got a three inch lift mainly to replace the worn out springs and seven leaf pack in the rear thats bent, new marlin crawler 4.5 inch shackles and a daystar body mount kit
heres the truck with no wheels trying to make it as low as possible as to be able to get the cab off with the engine lift my buddy let me borrow got it off today pics will come tomorrow hopefully .... that was interesting these suckers are heavy it may not look like much but it is thats about it for now i will update tomorrow and will get pics of the cab off and engine and what not
Old Aug 20, 2008 | 08:30 PM
myyota's Avatar
Just take your time and do it right, and your truck will be good as new when your finished.
Old Aug 20, 2008 | 10:54 PM
shaw_j's Avatar
Oh if only I had the time to do this!
Best of luck on your endeavor!
Old Aug 21, 2008 | 12:28 AM
drew303's Avatar
I feel your pain! goodluck
if your curious, check out mine https://www.yotatech.com/forums/f116...arning-122175/
Old Aug 21, 2008 | 07:27 PM
thanks guys sorry i forgot to post a picture today i will try to get to tomorrow before i get the engine out and all that good stuff
Old Aug 21, 2008 | 07:50 PM
20twinz's Avatar
One of these makes it easy.... 1hour.....complete truck stripped.
http://i274.photobucket.com/albums/j...0704081422.jpg
http://i274.photobucket.com/albums/j...0704081714.jpg
http://i274.photobucket.com/albums/j...0704081904.jpg
http://i274.photobucket.com/albums/j...0704082014.jpg
Good luck, im doing kinda the same thing but going a different route.
What did that frame cost you any ways?
Old Aug 22, 2008 | 03:26 PM
the frame was 1200 no rust holes at all nice n solid i wasnt going to try and look for a cheaper frame with no rust cancer especially in the pennsylvania area and i didnt want this one to slip away frome me
Old Aug 22, 2008 | 08:04 PM
ok heres the engine out
old crappy frame
cab just chillen i was sitting in it pretending it would drive lol i miss it
and my 90
Old Aug 25, 2008 | 07:12 PM
ok gots some more fancy pics i think you guys would like
Old Aug 25, 2008 | 09:34 PM
myyota's Avatar
Looks good, whats with the rusty rear end and springs sitting by the frame ?.
Old Aug 26, 2008 | 05:28 AM
20twinz's Avatar
I would say the springs are his old ones that he replaced with the 4.5" lift and the rear end....hasent painted it yet?....
Old Aug 26, 2008 | 06:55 PM
that rear came with the frame and the leafs its junk the housing may be salvageable and the one axleshaft that came with it theres leaves and in it
Old Aug 27, 2008 | 05:51 PM
so lol i have a question when i put the cab and bed on and other assorted crap... will those rear springs chill out a bit lol
Old Sep 5, 2008 | 07:19 PM
20twinz's Avatar
looks to be a bit higher in the rear....how much higher is it?
Old Sep 5, 2008 | 07:22 PM
alright made alot of progress... sortof i got the cab on
Old Sep 5, 2008 | 07:30 PM
its a three inch lift but to replace the old shackles i got marlins shackles and his are one inch over stock so i just got them i think it will look good like that though but ill have to see
Old Sep 5, 2008 | 07:36 PM
20twinz's Avatar
That 3" makes a big difference with clearance, and you dont even have a body lift in. Thats going to look good all finished up. Nice work.
Old Sep 5, 2008 | 07:37 PM
YOTABP's Avatar
They will, but not much. Plus the front will settle more w/ the engine going in.
Its deff gona sit higher in the rear.
Old Sep 5, 2008 | 07:45 PM
YOTABP's Avatar
Ditch the bed and make one out of tube
Great job so far though, truck is clean as hell now.
Old Sep 5, 2008 | 07:47 PM
yeah it it ends up being that much of a diff i will get marlins shackles for the front i got alot of new parts coming all from marlin haha new pinion seal for the rear there was no oil in the rear.... found out why it leaks like a sieve, i got a knuckle rebuild kit w/bearings, the solid pinion spacers, and for some bling i got the low profile magnetic drain plugs
its really great bringing this thing back to life the only issue concerning me is the frame being slightly bent but ill get that pulled and straightened no matter what it takes
