bent or broken valves on 3VZE 95 4runner
I think i might have bent a valve because when i turn it on there is a very loud knocking sound on the passenger side of the motor.... Is there a possibility that the valve or valves (hope not) may stilll be in good condition, maybe just adjust the timing a little bit, or since im hearing that noise does that mean i need to replace it for sure..
alright kool,,,, definetly gunna cross my fingers on this, im going to work on it in the morning,,
when i started it up it took a few seconds for me to hear,, then when i heard it, it would sound for about 2 seconds then stop,, so im thinking that could be a good possibility
thanks
thanks
ok,, cuz a couple days ago the timing was way off and when i started it up the motor was just shaking like crazy,, so that would also be a good possibility.. and yes to your answer about the hearing the noise for a couple of seconds and then it would go away...
but also i forgot to mention is that is starts making that sounds again... so i that still possible about the motor mounts?
well i took my head off and found that there was a nut that somehow got into the pistons and totally f***ed everything up... so now im wondering what would be worth doing,,, buying a new car.. which i dont have the money for right now.. or putting in a 3.4L from the 96 and up.. can anybody give me some suggestions...thanks
Jun 1, 2021 01:51 PM
