2nd gen factory roof rack location dimensions
A little help please..I'm installing a factory roof rack on my 4runner that never had one this weekend. I want to avoid removing the headliner to verify the holes will avoid the roof support ribs..can someone tell me where the factory rack is locateed on their rig...the approx. dimension from the back window opening verticle to the start of the rails...and the dimension from the moon roof opening to the front of the rails should work..thanks in advance for the help..
thanks olharley...you sent me your wright-up already...much appreciated..it will come in handy for sure..could you check on those dimensions?
There is a write-up on this at:
http://www.ultimateyota.com/index.ph...6&topic=2218.0
I installed a factory rack I got from the wrecker - mine is only 36 1/2" long, off an earlier model. The holes in the factory rack are just shy of a foot apart (30cm). I put the first hole 10" from the back window frame edge and did not hit anything. I used nut-serts and stainless bolts to mount the rails. I can't speak for the longer rails, I specifically got the shorter ones as I didn't want to risk hitting any sunroof bits.
Hope it helps.
Hope it helps.
still looking to verify layout dimensions...I measured one on someone elses rig yesterday...7-1/4" to first fastener closest to moonroof. 8-1/4" to first fast. from back window.
Steezy96yota
Jul 6, 2015 10:00 AM
