FS: 87 4Runner 22RTE SR5
SOLD
~193,600 miles on vehicle, ~300 miles on engine.
Original Southwest vehicle = no rust anywhere. Engine rebuilt to OEM specs except bored .020 over with rebuilt 22RE head. New timing gears, chain, steel guide, oil pump, water pump, timing cover, engnbldr head bolts, engine & turbo gasket set and crankshaft dampener pulley. Vehicle interior is nice except for 2 (~1 1/2" size) wear patches on the drivers side seat. AC blows cold. Electronic dash works fine. Power windows, power locks, power mirrors, power rear window, power antenna all work. All interior and door lights work. 7 way drivers seat adjustments all work. Rear seat heater works. This vehicle has all the options including sunroof. Inside sunshade cover included. Turbo replaced with unit with much less mileage. Turbo spools up with vigor. Halogen headlights, taillights, brake lights all work. Almost new battery. Aluminum Wheels are stock and tires have a few thousand miles left on them. Spare appears new. Other items replaced; shifter bushings, tail light lens, rear window wiper, power antenna. Transmission shifts good, OD works, 4x4 works. Engine starts easily hot or cold. Runs great. No leaks, no codes. Body & suspension are tight. No squeaks or rattles.
Issues: Windshield has vertical crack to the right of center. Rest of glass good. Fuel door release cable not working. New cable included. Gas door key lock works. Drivers side mirror missing mounting bolt cover. Rear bed carpet is dirty and needs a good cleaning or replacement.
$3500.00 obo. Vehicle also for sale locally.
Location Southwest New Mexico
Pics: www.ruralinternetservices.com/87toyota
88yodabasket
Jul 13, 2015 01:32 PM
