purchasing truck with power steering issue
ok im buying a 1897 22r pickup..
its having issues with the carb ..
but the prev owner said that when it did run the pwoer steering pipe was getting extremly hot and he shut down the truck.. what could cause this?? also the truck has a ground issue he said which is why it doesnt start...
its a brand new rebuilt 22r with no miles just noone hooked it up right...im going there tommorow with a camera...
i need to know where the ground are.. one from alt one from power steering pump??? one from battery?? one from engine block??
What exactly is a "power steering pipe"?
I would be leary of buying a truck fresh off a rebuild that didn't run. If he ain't smart enough to get it installed back like he took it out he probably isn't smart enough to rebuild it either.
im getting it for a parts truck price.. i trust the rebuilder of the engine 100 percent .but not whats been done to it since. i assume he ment the hose coming from the power steering pump... i have 22re trucks i can look at.. i am just going to work on the truck at the owners place for a bit and see if i can get it running..
worse comes to worse i put a 22re in it.
it has leafs in the rear which my runners dont and no rust at all which is so rare up here...
LoL ^^^
The power steering hoses will get hot. Ive ran my setup without the front cooling pipe (that extends out infront of the radiator) for 2 yrs now no problems. Even in the summer. I wouldnt be to worried about it getting "hot" unless you plan on driving in the Sahara, which i wouldnt advise =p
As for it not running, well theres a ground behind the head and one on the left side near the bottom that connects the ground on the battery.
500 with 3 exhaust 2 extra rads 1 set of miuchelin 32 a/ts and one get of 31s
bed has been bobbed but just metal screwed not welded yet.. and it has some dents...
ill take pictures today
its going on the street.
i might have to put a open diff in it..
then its getting trail duty once i can drive it to the trail cause my trail rig right now is a money pit! sometimes you gotta cut your lose's...
soon as this rain clears im going to get pictures
STAY TUNED!!!!
STAY TUNED!!!!
ok i went and looks at the truck and the steering is defiantly different.. im going to post a build up thread in hopes to get more help and support!
look for it momentarily
Sounds like a good idea to me. $500 and I'm sure the block/head is useable if rebuilt recently. I'd buy it unless you are looking for a dependable DD.
yeah i started another thread im gonna go tommorow again maybe clean it off and bring some tools fluids and fsm.. hopfully the prev 2 owner prior to the guy im getting it from get back to me tonight with some questions i h ad about the engine!
voiddweller
19
May 2, 2016 09:10 PM
Bamripzit
Jul 19, 2015 01:17 PM
