'89 3.0 V-6, Hard to Start
Old Jul 13, 2008 | 09:59 AM
Mattmesa's Avatar
Question '89 3.0 V-6, Hard to Start
Hello,
I have bought a 1989 4wd extended cab with the 3.0l V-6, I've had the valves adjusted,new Vacuum Lines,new TPS, new ECTs,new Fuel filter, Air Filter, Intake Tube (bellows) and Sparkplugs/wires. Now my problem is still the same as when I bought it just not as bad. In the morning the engine doesn't want to start. After work or anytime that the air is about 70 or above it starts right up. Also, it loses power when the engine is switching over to ECM control, about 1 mile from where it starts. After the engine has reached running temperature no problems exist except one it is a gasoholic and get about 10 mpg, Oh that hurts!
Any help would be Greatly Appreciated, Thanks,
Matt
Old Jul 13, 2008 | 10:22 AM
DeathCougar's Avatar
Yet another "replace parts til it works" lol.
You need to TEST the parts before replacing them willy nilly.
Sounds to me like your cold start injector switch is bad. Same exact problem on my 85 MR2. Test that switch (located at the back of the engine, in the coolant sensor block) and go from there.
Old Jul 16, 2008 | 06:10 PM
Mattmesa's Avatar
Cold Start Injector Time Switch
Thanks for your Idea, only one problem. I can't find any specs on the switch, I found out it is still a thermistor and I would need the cold resistance and hot resistance to know if mine is good. According to my local Toyota dealer mechanic they don't have a test, but they will sell you one for $180.
Old Jul 16, 2008 | 06:40 PM
Cyberman's Avatar
INSPECTION OF START INJECTOR TIME SWITCH
MEASURE RESISTANCE OF START INJECTOR TIME SWITCH
(a) Disconnect the connector.
(b) Using an ohmmeter, measure the resistance between terminals.
Between terminals Resistance (ohms) Coolant temperature
STA - STJ 30-50 Below 50 deg. F
70-90 Above 77 deg. F
STA - Ground 30-90
When you look at the teminals with the connector "latch" to the bottom, STA is on the left.
Old Jul 17, 2008 | 06:52 PM
Mattmesa's Avatar
Thanks
I found a switch off of a Runner that looked similar and measured its resistance and it's within your specs. I'll see in the morning how it works, thanks.
bigjstang
Jun 2, 2025 03:56 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Avenged
Jul 9, 2015 07:55 AM
colinmil
Jul 6, 2015 04:03 PM
