EVAP Canister on older P/U
There were many threads on the EVAP canister buzzing after the ignition was off on 96 4Runners. Has anyone had this problem with the older toyotas? In the last two days or so, when I turn off my pickup, it seems the purge line on the canister intermittenly buzzes? You knock on the canister, it quits.
It's a 89 4cyl 22RE M/T.
It seems weird that you could actually hear that check valve?
Ya I did that to my old can in my 94 4runner and it shot out some black stuff. blow into it and then shake it a few times and repeat. When I did it it would shoot out some dirt then seem clean and Ide do it a few more times and more would come out.
Try it and see if it helps!
kawazx636
Oct 6, 2021 03:03 PM
TheBFA
Feb 15, 2020 06:55 AM
