truck just started puffing blue smoke
so in the last two weeks my truck has been burning oil at start up.
just a puff of blue at start up but the exhaust smells different then usual even after the blue goes away.
any ideas on what might be causing it to suddenly burn oil like that.
the only thing i had done different is use a wix filter instead of fram when i changed oil a few weeks ago.
5-30 is WAY too thin for these engines, especially during the summer. They originally called for 20-50 until 1984 for so-called emission reasons. You should be at LEAST be using 10-30.
if it's not below freezing, there is no real reason to run a 5wXX oil. you can run a 15wXX oil down to freezing temps.
Smoking on startup implies either leaking valve seals or oil puddling in the intake. Thin oil will tend to become aerosolized more easily than thicker oil and could get more easily sucked into the intake through the PCV valve where it could stick to the intake and drip down to the valves when the engine is off.
zd92655
Mar 6, 2022 12:58 PM
bigblue82
10
Jul 6, 2015 08:27 AM
jmc88runner
Jun 18, 2015 03:39 PM
