Sponsored by: CARiD
tire and wheel about ready to fall off- help
Old Jul 6, 2008 | 11:40 AM
88Yota4runner's Avatar
Exclamation tire and wheel about ready to fall off- help
yesterday my truck started doing something wierd... everytime i push on the brakes my truck wobbled kinda viciously, so i parked at my girlfriends aunts house to see whats wrong... and my front driver side wheel is like this --->
[]===\ \ also whenever i turned right it was like the brakes were engaging themselves on just that tire... so something HAS to be broken/rubbing or whatnot.. its an 88 4runner IFS i have pictures but i cant get them to upload at the moment, what do you think?
Attached Thumbnails tire and wheel about ready to fall off- help-pictures237.jpg   tire and wheel about ready to fall off- help-pictures231.jpg   tire and wheel about ready to fall off- help-pictures230.jpg
Old Jul 6, 2008 | 12:10 PM
any help would be awesome.
Old Jul 6, 2008 | 12:16 PM
CJM's Avatar
CJM
So your saying the tire is cocked to the side? Could be an alignment issue, your a-arm coulda fallen off or broke, shock coulda broke off, etc.
TOYOTA 1's Avatar
wheel bearings, or your lug nuts are loose..
p.s check the lug nuts first.
Old Jul 6, 2008 | 12:29 PM
i just took another look at it and something just seems MESSED UP, what exactly takes place when an A-arm falls off?
Old Jul 6, 2008 | 12:40 PM
TOYOTA 1's Avatar
i doubt your a arm is falling off that would more than likely cause a wreck, and your tire would have munched up in your fender... check your lug nuts then check your wheel bearing.
Old Jul 6, 2008 | 12:43 PM
4Crawler's Avatar
Lift the front end up on blocks and have a look at things and grab the tire at 6-12 o'clock and give it a good tug both ways. If a ball joint is going out, you'll be able to see movement there. Could also be a wheel bearing that worked loose or wore out. Also check 3-9 o'clock and feel for play there. Might be tie rod ends loose or worn. If play at both top-bottom and side-side, then it is likely the wheel bearings.
Old Jul 6, 2008 | 12:48 PM
ok so i just backed up my truck and parked it with the wheels COMPLETELY straight, and when its straight the wheel doesnt lean AS badly, but when i turn left it just looks like its about ready to give up, when i turn right the brake engages on that tire... wtf?
Old Jul 6, 2008 | 12:49 PM
bigt's Avatar
sign up to photobucket.com we need pics
Old Jul 6, 2008 | 12:51 PM
ok i gotta fix something to get my camera to work again, hah ill be back asap
Old Jul 6, 2008 | 12:53 PM
TOYOTA 1's Avatar
Old Jul 6, 2008 | 12:54 PM
apalmer1's Avatar
yeah im gona jump on the wheel bearing train, check your balljoint also but as bad as your making it sound it really seems as though the wheel bearing is completely destroyed. lift up only that tire, and put a 2x4 under it and pry up, see if the tire moves up and down by itself, if so balljoint is gone. if the wheel bearing is out the whole thing will spin with a wobble to it.
Old Jul 6, 2008 | 01:36 PM
ok i got a few pictures up on my first post
Old Jul 6, 2008 | 01:42 PM
TOYOTA 1's Avatar
looks like the wheel bearing to me!
ok also, depending on if it IS the bearings, how close was i to actually possibly losing a tire on the road... and also how much am i looking at having it fixed and how difficult is it to fix yourself?
Old Jul 6, 2008 | 01:47 PM
TOYOTA 1's Avatar
looks like the tire was getting close to working its way off..
as of cost I'm not sure.. id just price the parts, then have a shop give you an estimate
Old Jul 6, 2008 | 01:58 PM
well crap, if im gonna end up having to pay alot of money to get this fixed, would now be the time to think about finally just getting a SAS done?
Old Jul 6, 2008 | 02:03 PM
also what exactly do i look for parts wise? just wheel bearings or like do i have to replace the whole driver side a arm or anything?
Old Jul 6, 2008 | 02:05 PM
TOYOTA 1's Avatar
well that realy depends on what you want to do.
i can tell you this, new wheel bearings is gonna be cheaper than an sas.
Old Jul 6, 2008 | 02:07 PM
should i just call this an excuse for finally bringing myself to have one done?
