Can someone please help me identify this part?
I am in the process of removing the 3VZE out of my 90 4runner and found this piece mounted on the driverside below and in front of the A/C condensor.
Also does anyone know the P/N for the tube that runs from the PCV valve to the upper intake manifold? I bought this truck for $300 and it was missing this hose. I am going to start the rebuild here soon, broken #6 con. rod, and want to replace all sensors, most sensors, etc. Thanks for the help guys.
Tim
Tim
that is the AC ballast resistor (may be called something else, not sure) but it mounts to the middle front of the core support, behind the grille/bumper and in front of the AC condensor.
The "ventilation hose" probably has part number 12261-65010- (probably because I'm surely missing a prefix or suffix, but this may get you started.)
I replaced mine with a piece of "ordinary" vacuum hose, but it does kink on the curve and I'd probably be better off with the right hose. Let us know what it cost you!
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
Jan 30, 2026 01:57 PM
FS[GreatLakes]: 22RE performance and stock parts (pic heavy)
May 20, 2016 10:27 AM
rushw
Jul 18, 2015 01:46 PM
