Longer Shackles
Old Jun 8, 2008 | 08:42 PM
pyro's Avatar
Longer Shackles
If I were to put a 6.5" longer shackle on my rig what would i need to change? ie. longer brake lines. I already have a 3" suspension lift.
Old Jun 8, 2008 | 09:02 PM
4x4YOTA's Avatar
you wouldnt have to but if you do a lot of wheeling I would mine were streched past limit with a 4.5" lift I bought trail-gears brake lines and they were awesome paid $69 for the set of 3 + shipping and its a good investment to me. better safe than sorry
Old Jun 11, 2008 | 01:42 PM
hmmwv15's Avatar
If you were just putting the shackles on it would be fine but since you have a 3" already I would say extend them. another tip for the front is to bend the tabs that the top of the rubber brake lines are connected to in towards the tire instead of back towards the back like they are stock. Gives a bit more play.
Old Jun 11, 2008 | 02:27 PM
strykersd's Avatar
I run 3" downey leaf springs with 5.5" shackles and I don't have any issues. The only issues I've had with the longer shackles is that I had to extend my bumpstops. Before I extended the bumpstops I found that when I flexed my rear leafs inverted, which I imagine couldn't be good for the life of the leaf springs.
Old Jun 11, 2008 | 02:31 PM
4Crawler's Avatar
Is this a 6.5" longer than stock shackle or 6.5" longer overall or center to center?
- http://www.4crawler.com/4x4/ForSale/Shackles.shtml#FAQ4
You may need shims to correct pinion and caster angle changes along with the above noted items:
- http://www.4crawler.com/4x4/ForSale/...es.shtml#FAQ12
Old Jun 14, 2008 | 10:39 AM
pyro's Avatar
6.5in center to center
kawazx636
Oct 6, 2021 03:03 PM
LittleUgly
15
Jan 2, 2020 01:30 PM
White Stripe
Oct 6, 2015 10:47 AM
Brodetski
Sep 30, 2015 11:50 PM
oldblue
Sep 28, 2015 04:07 PM
