Tow trailer with 7" Lift
Towing a trailer with 7" Lift ???
Hey,
Can you tow a small trailer (2 dirtbikes), with a 4cyl 4runner 5spd, with 4"susp lift and 3" body, 35" tires, and 4.88s?
Will I have any towing problems is my main concern?
Thanks
Thanks
if you keep the trailer under 1000 pounds or so you'll have no problems. just give yourself extra room for braking and corners.
you'll need a receiver with the appropriate drop so the trailer sets level or slightly tongue down. you want the trailer that way because most trailer axles have a slight positive camber to them (the tops of the wheels tip out slightly) and if the tongue is above level, the trailer will have a tendancy to wallow side-to-side at speed
you should also have at least 10-15% of the total trailer weight on the ball (if the trailer, loaded, weights 1000 lbs, you want the tongue itself to weight 100-150 pounds or more) this helps prevent the trailer from wallowing as well.
if the trailer, loaded, weighs more than 1200 pounds or so, I recommend electric trailer brakes be added to the trailer and a controller in your truck.
I see you're in metric country, but you get the idea.
Scatterbrain
14
Aug 31, 2015 06:26 AM
dropzone
Aug 11, 2015 05:16 PM
defrag4
Jul 31, 2015 10:50 AM
shadowbirdie
Jul 21, 2015 10:38 PM
Jeffreynmandy
Jul 18, 2015 08:26 AM
