Companion Flange Vibration Issue
I'm having a vibration issue that starts around 50-55mph and goes away as soon as I hit 65 or so.
I've had the front end inspected by two different shops and had all 4 tires and wheels balanced twice and the problem is still there. I also replaced the two u joints on the rear drive shaft.
I've been doing some searching and I think it is related to the companion flange some way or another. I removed the driveshaft to check it out and found a strange looking nut with some kind of locknut inside the nut itself.
How do I go about removing this nut or tightening it? Can I just buy a new nut and lock ring or whatever it's called?
Any help/advice appreciated.
It's a 93 truck with the 22re 4wd.
Get your rear pinion angle checked. Inspect the springs for any sign of 'wrap', where the wheels cause the spring to twist. Get the driveshaft balance checked.
Now... where do you feel the vibration? Steering wheel? Floorboard? Seat?
Yeah,,, i had a weight come loose from the d/s and it caused all sorts of vibration @ 55, about a month later... lost another weight @ 85mph, and shortly after the weight flew off, so did my driveshaft!!
Actually, it isn't all that odd. Consider vibrations in the driveline like you would sound vibrations (music)- they have harmonics and sometimes the harmonic vibrations cancel out things and make the vibration seem different than it really is.
Sweet, what part you from, I live in cornish, between standish and ossipee nh, I know of some CRAZY trails..see avatar
some is normal, if you can turn it like say 1/2" thats prob too much...or enough to feel it any way, my rear diff is a frankendiff, mad from parts of 3 or 4 others, it has tons of backlash, and i been runnin it for 50k, it will eventualy cause other probs, but its not the end of the world, if you were inclined to do so, you could pull it and adjust it.
My u joints were shot from the PO so I can't imagine it's ever been touched and it's got 230k on it.
I'm from Rockland about 2 hours north of you. There are some crazy trails up here to.
http://www.eastcoastrover.com/ these guys here have a bunch of trails a mile or so from their shop that everyone rides on up my way.
crammit442
7
Nov 29, 2017 12:30 PM
