Leaking fuel injector 89 22re
Old May 17, 2008 | 04:55 PM
tomh's Avatar
Hi guys.
I replaced my 22re lower intake manifold last week, used all new gaskets and o-rings. everything ran great no leaks. Today it got hot out, hit around 90, I noticed the truck was hard to start, then as I was driving smelled gas.
When I got home looked under the hood and sure enough # 3 fuel injector was leaking pretty good. Which explained the hard start, since I lost fuel pressure while it sat.
What is weird is that it had no leaks at all since i re-installed everything,until today. Anyone have any tips on putting the fuel injection system back together so this does not happen again? I lubed the o-rings with fuel like the book said. Moving the injector around did nothing to stop or slow down the leak.
Thanks for any ideas or tips.
Old May 18, 2008 | 07:03 AM
tomh's Avatar
anyone?
Old May 18, 2008 | 07:07 AM
ahickman's Avatar
Did you replace the injector seals with new one? They should be very soft and pliable. Are all four injectors the same make/brand?
Old May 18, 2008 | 07:09 AM
foot0069's Avatar
Use this link to get a pic of my idea. Had the same problem when I put mine back together. Had to replace the grommets as well. Got all new o-rings and grommets from Toyota. Think it was less than $20.00 to do all 4 injectors.
OOps here it is http://personal.utulsa.edu/~nathan-b...31injector.pdf
Old May 18, 2008 | 09:12 AM
imtxn's Avatar
Hello, Was wondering if you used seal glide when you replaced the injectors? Me
Old May 18, 2008 | 02:01 PM
tomh's Avatar
all new o-rings and grommets from toyota were used, just lubed with fuel, never heard of seal glide. the dang grommets are like 4 bucks a piece. i hope I dont need to put all new ones this soon.I will have to check out the seal glide.
I believe they are all the original injectors.
Guess when I pull it apart tomorrow, the problem will make it self known. I am guessing I just didn't have the injector seated straight, and after a week of driving it vibrated enough to start a leak. fun stuff.
Old May 18, 2008 | 05:07 PM
84sr5yoty's Avatar
I just used petroleum jelly. Worked for me the 3 times I pulled all of the injectors out.
Old May 19, 2008 | 09:24 AM
tomh's Avatar
ok as suspected the o-ring was sliced almost thru. how the heck did that happen, i cant find any sharp edges. i think i will try the petroleum jelly. thanks for the tip.
Old May 19, 2008 | 03:31 PM
84sr5yoty's Avatar
Fuel isn't a good lubricator and probably caused the o-ring to bind and break. The FSM clearly states NOT to use engine oil. Like I said, use petroleum jelly and you'll be fine.
Old May 19, 2008 | 03:42 PM
SEAIRESCUE's Avatar
Wheel bearing grease or petro jelly works great.
jbv808
Aug 6, 2021 04:47 PM
Eggslinger
Jun 8, 2019 03:32 PM
Doug4320
Mar 24, 2018 10:11 PM
steve miller
Oct 10, 2015 01:40 AM
karbin
Jul 5, 2015 11:37 PM
