spark plug connector grease !?!
so im at o'rielys buying a set of ngk plugs and some wires
Trust me, if i had money for toyota plugs and wires i would deff go get those.
but
i decide to pick up some of this stuff.
anyone else believe in using it??
but
its called dielectric grease. keeps water out of electrical connections and such. works wonders for not corroding and keeping connectors clean and easy to disconnect etc. i think it works awesome.
Are you talking about anti-seize for the threads or dielectric grease or whatever it's called for the boots? I think both are good to use. I don't pay $1 for those little packets at the counter, though. You can buy a larger tube for not much more and then you have it.
Rob
Rob
No don't put the dialectric on the end of the spark plugs, certainly not in the electrode area. Others have mentioned putting anti-seize compound on the threads to facilitate easy removal in the future. Anti-seize is sold at all auto parts stores.
Just coat the rubber boot with your finger along the inside lip or around the ceramic body of the plug, either way will work & it will seal out moisture & facilitate boot removal in the future. Don't glob it on.
montanatruck
Feb 26, 2017 07:07 AM
