help identify parts 94 4runner 3.0
I've got my engine repaired with a fresh crank and bearings and have some parts I can not find a place for.
Can anyone please help? These are from a '94 3.0 5-spd
Also, I wonder if I need to bolt anything on to this circled hole in the picture below before I put the engine back into the car?
Thanks for any help.
Bill
Bill
Those are brackets for your power steering pump. In your picture the one with three bolts is upside down. It bolts to the block and the adjuster bolt connects to the other end. You must have air conditioning since the other piece you have a picture of looks a little different than mine did. Mine was straight and yours is curved to make it around the AC. It bolts down low to brace the pump.
I posted pretty much the same pic when I was assembling my engine.
Thanks for the reply. I do have air conditioning, and the a/c compressor bracket sits against the lower right front corner of the block. I can see the marks on the back of the heavy mystery bracket where it appears to have been bolted against the block, but I cannot find any matching position for it anywhere near where the power steering pump mounts.
I think I'm going nuts.
I just ran down to the garage and took a few pics. I added captions to them to help you. Let me know how it goes.
http://picasaweb.google.com/Green93T...96858545672322
http://picasaweb.google.com/Green93T...96871430574226
http://picasaweb.google.com/Green93T...96892905410722
Jason, thank you sooooo much for taking the time to take the photos and post them for me. I finally got it! I really know better than to tear an engine down without labeling the parts, or at least taking a few pix to help on the other end.
Here is a picture of how the power steering pump bracket fits on my engine for the next poor schmuck who has the same problem:
