Anyone install a new upper ball joint lately?
I just put in new upper ball joints and spacers. Not sure what you are asking. The ball joint should have the studs(bolts) already attached. I had to tap mine out and use the longer versions with the spacer kit. If they are not attached, just tap them in with a small hammer or something.
I resolved my issue by getting some allen bolts, nuts, and nylock nuts to keep the regular nuts from getting loose.
I also ran into a similar issue with rear brake shoes. There are a pair of studs that go in to mount the adjuster. Those had spines as well. I tried the freezer trick, no good. I ended up grinding the spines off with a Dremel.
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
FS[SouthCent]: TX Third Gen UCA and LCA low miles Taco
KyleT
Jul 21, 2015 07:54 PM
