22RE Block Drain Plug...coolant
Well, we were changing a couple rad hoses and decided to flush the whole system as well. The drain plug (block) was almost pooched/stripped so I'm wondering where I should get a new one. Dealership? Does anyone have any ideas? I could re-use this one but would be afraid that it's never coming off again...well at least without doing some damage. Thanks.
You could, but I'd just try and fine another one from someone parting out or at a bone yard. Much cheaper....maybe even free.
If the threads aren't completely destroyed, you could try repairing the threads with a bolt chaser or die. Make sure the block threads aren't pooched, also. You'll back in the same boat trying to put a plug back in.
I'm not sure if loc-tite or anti-seize would be appropriate in this situation. Whichever is, either one will lubricate the threads and make reinstalling easier. Less chance of it sticking and crossthreading.
What's your temp gauge setup like? Any details? And as for teflon sealant...is it a tape or liquid/glue? I imagine it would have to be resistant to the high temps at the block though eh?
