Exhaust system for longbed Tacoma?
Hey guys!
I've lurked on here for a while and have tried to absorb as much info. as I could, but I finally broke down and registered.
I'm new to truck/suv ownership and so far the Tacoma has been awesome, I know I made the right choice.
2004 Tacoma/Extended Cab/2wd/74.5" bed/Auto/TRD pkg.
Ok now to my question, and I did search on the topic but couldn't find anything specific. I was looking to buy a cat-back exhaust for the truck but I can't find one that fits the longbed Taco?? The only two companies I've seen that even make a cat-back are Gibson and Magnaflow, but their systems only fit the shortbed trucks. As far as I know the only shortbed trucks are the double-cabs, so what gives?! There has to be a longbed exhaust out there! Any info. would be much appreciated.
Jesse
I'm new to truck/suv ownership and so far the Tacoma has been awesome, I know I made the right choice.2004 Tacoma/Extended Cab/2wd/74.5" bed/Auto/TRD pkg.
Jesse
If you're not turbo/supercharged, or have extensive engine modifications, putting an exhaust system on a 3.4L will net you pretty much nothing. If you're wanting it for the sound (which is what I'm guessing you're trying to do here), there is a much much cheaper method. Get a muffler welded on (Magnaflow, borla, or a generic at your local muffler shop). You get the sound without the $$$$.
Oh, and thanks!
But no one knows of any cat-backs designed for the longbed Taco?
Double cab short bed and extra cab regular bed tacomas sit on the same frame. The only thing different is the body and bed, running gear (including the exhaust) is the same. I'm 99.9% sure of it.
Ok now that makes sense!! The overall length is exactly the same with the doublecab/shortbed and extndcab/longbed! The fitment guides are a little vague on most sites I've visited, so this makes me feel better.
Thanks to you both for the help, this place is great.
I'm still reading through the newbie section, those threads are full of valuable info.
FWIW - I own a Performance/Muffler shop here in Florida. Find a reputable shop and have them install a Magnaflow muffler for you instead of the cat-back. It's going to be a lot cheaper, Magnaflow has a lifetime warranty on their mufflers, and you can add a high flow cat at the same time or later down the road for a little more tone. It should come out cheaper than purchasing a cat-back system from somebody. check around
I added a Magnaflow muffler and high flow cat to my 99 4runner and it sounds great. It didn't turn it into a race car, but I did notice a little bit of difference in the power.
Hope it saves you some money
Thanks for the suggestion! I'm considering exactly what you said, buy a good performance muffler like a Magnaflow, and have a shop install it. But I'm still leaning towards the cat-back just for the convenience of swapping out the old one for the new one. And I could hang on to my stock exhaust in case I ever wanted to put it back on.
If I installed a high flow cat would that cause any problems with emissions testing? I guess it depends on exactly which cat I used?
WTB[PacNorWest]: WTB - Tacoma/4runner 3.4 Charcoal canister and igniter
94whiterunner
Jul 12, 2015 07:15 PM
Poncho0206
Jul 10, 2015 06:21 PM
