Tach Help
Old Mar 24, 2008 | 07:23 AM
Flash319's Avatar
Tach Help
I am trying to get my tach to work with my diesel swap. I have used a prox sensor to trigger a relay to pulse a +12 signal to the black wire comming out of the ignition modual on the fender. No workie.
The original gauge cluster was from a basic guage package, just speedo and dumby lights. There was only 1 wire that was missing from this harness so I hooked one up to it. I tryed on this wire with still no luck.
My other guages are working so it is not a fuse, I don't think? What am I not doing right....................
Old Mar 24, 2008 | 08:52 AM
R.DesJardin's Avatar
Sensors
As I understand it a tach signal is a digital signal and possibly AC also. Using an analog prox won't give you what you are after. Why not rob the parts from a distributor and use it as you are using the prox. sensor. Then there would be no doubt on getting the right signal.
shisha1999
Mar 3, 2016 07:09 PM
Jdgarrison
Oct 1, 2015 05:22 PM
Jdgarrison
Oct 1, 2015 02:11 PM
imhousing
Sep 10, 2015 02:04 PM
O Holy P
Aug 18, 2015 02:33 PM
